Date/Time: Fri, 31 Jan 2025 17:51:48 +0000
Market Depht Historical Graph
View Count: 665
[2019-05-22 14:09:03] |
User75096 - Posts: 48 |
in 1920 if mdhg is open , it stoped working if i open a secound instance with it over dtc subinstance, please have a look, thanks |
[2019-05-22 15:35:02] |
We do see this problem and we are looking into it.
[2019-05-22 15:56:17] |
We are releasing version 1921 in about 10 minutes.
[2019-05-22 17:28:41] |
next problem if dtc protokol is not enabled there is no marked dept pulling/stacking you have to enable it than disable it and it is still working
[2019-05-22 21:18:06] |
This has been resolved and we released a new revision. We did not change the version number. Update again with Help >> Download Prerelease.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-22 21:18:23
