Date/Time: Fri, 31 Jan 2025 20:02:18 +0000
Do Not FIND FIELD-CODE-BEGIN-RECORD
View Count: 1043
[2019-05-22 12:43:49]
User355173 - Posts: 9
Hello, I'm experiencing a problem. Every time I change the bar period, I get this error message: do no find FIELD-CODE-BEGIN-RECORD.
Can someone help me please with this?
[2019-05-22 14:33:52]
What is the full error message and where do you see it?
[2019-05-22 15:08:38]
Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 0. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2019-05-22_UTC.data | 2019-05-22 11:03:34.691 *
TradeActivity files query time: 0.142049 seconds. | 2019-05-22 11:03:34.831
Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 0. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2019-05-22_UTC.data | 2019-05-22 11:03:34.842 *
TradeActivity files query time: 0.011197 seconds. | 2019-05-22 11:03:34.842
Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 0. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2019-05-22_UTC.data | 2019-05-22 11:03:46.679 *
TradeActivity files query time: 0.003536 seconds. | 2019-05-22 11:03:46.679
This error happens in multiple occasion, always when I change the period in the chart.
Date Time Of Last Edit: 2019-05-22 15:21:34
[2019-05-22 15:20:59]
There is something wrong with this file:
Exit from Sierra Chart and delete that file.
[2019-05-22 15:33:57]
I have deleted that file and then all the files into the tradelogs folder but this message keeps popping up.
TradeActivity files query time: 0.000557 seconds. | 2019-05-22 11:31:37.084
TradeActivity files query time: 0.000107 seconds. | 2019-05-22 11:31:37.084
File is empty: TradeActivityLog_2019-05-22_UTC.data | 2019-05-22 11:31:48.755
Error opening: C:\SierraChart\TradeActivityLogs\TradeActivityLog_2019-05-22_UTC.data | 2019-05-22 11:31:48.755 *
TradeActivity files query time: 0.000458 seconds. | 2019-05-22 11:31:48.755
Flagging to reload Trades list in charts | Symbol: F.US.ENQM19 | TradeAccount: 757452 | 2019-05-22 11:31:48.755
Flagging to reload Trades list in charts | Symbol: F.US.YMM19 | TradeAccount: 757452 | 2019-05-22 11:31:48.755
thank you.
[2019-05-22 15:57:19]
you were right! after few restarts and everything seems to be solved.
Thank you!
[2019-05-22 16:18:37]
You should not have to do anything other than exit, delete the file and start again. Certainly not a few restarts. We will test this.
[2019-05-29 14:15:46]
After restart, everything was deleted in Spreadsheet System for Trading.
We definitely do not accept this as a valid report at all. It is not even technically valid. Deleting one of the trade activity files has no effect on a particular Spreadsheet or an instance of a Spreadsheet study, other than potentially the reported Position quantity and fields like that.
Also the error is not something which would be triggered by updating Sierra Chart either. There is a problem with the data in one of the files like being incomplete. Possibly caused by an abnormal shutdown of Sierra Chart.
Date Time Of Last Edit: 2019-05-29 14:17:37
[2019-05-29 14:47:03]
Those messages are ok. Those just indicate the query times. Were these the messages you were referring to initially? Those do not indicate any kind of problem.
Date Time Of Last Edit: 2019-05-29 14:47:39
