Date/Time: Sat, 01 Mar 2025 20:06:07 +0000
VbP help required
View Count: 705
[2019-05-22 06:28:09] |
User745789 - Posts: 368 |
Hello, I need SC support please. I would greatly appreciate it. 1. How do I get those green VAH and VAL to extend to the end of window, and still be able to use the individual SG settings for each line? See settings. As discussed in a another post, "Extend Value Area" does not solve the problem. 2. How do I get the labels and lines (Valley, POC etc) to remain on screen when the time period from which the VbP profile is no longer on screen? Eg, that VbP is drawn for the previous daytime session. If that session time window scrolls off screen, then all lines and labels from that profile vanish. I am using Volume Graph Period Type = From Start Date Time to End Date Time. This methods seems to be the only solution I can find to my other (unanswered) VbP issues in Sierra Chart. Date Time Of Last Edit: 2019-05-22 06:30:18
[2019-05-22 23:47:32] |
Could I please have some customer service on this issue. "Always display last profile within view" doesn't solve the issue. If the time period from which the profile is calculated is not within the view, then various lines and labels from the profile vanish. |
[2019-05-23 21:38:34] |
There is not support for what you want but we will see about adding this functionality as a new extension option.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-23 21:38:43
