Date/Time: Sat, 01 Mar 2025 20:14:01 +0000
Running two Instances of SC with two different Interactive Brokers accounts
View Count: 651
[2019-05-21 22:21:47] |
John M - Posts: 171 |
Hello, Yes, our favorite IB brings me yet another question for you. Sorry... I set up two different IB TWS accounts with two different API port numbers, 7496 and 7495. When I bring up the sub instance of SC, it goes to the first IB account on 7496. How can I get the sub instance to address the second IB account with port number 2495? I looked thru the documentation and Global Settings in SC but didn't see anything on that. thank you |
[2019-05-22 04:10:23] |
You just need a completely separate instance of Sierra Chart as explained here: Using Multiple Data and Trading Services at the Same Time Not a sub instance. You then configure each instance as you require and to use Interactive Brokers with different port numbers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-22 04:11:18
[2019-05-22 13:21:52] |
Thank you, I figured it was something along those lines. Can I copy the contents of the existing SC folder to a new folder named "Sierra Charts 2" and then simply change the SC API port number to match the TWS port number or do I have to do a new download and installation? If I have to do a new download and installation, can I copy the Data folder from the original SC that has all my charts and setups in it to the new folder? |
[2019-05-22 14:32:58] |
Here is the documentation for how to do this: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-22 14:33:06
