Date/Time: Fri, 31 Jan 2025 17:43:01 +0000
[Programming Help] - The automatic works with SIM but when I use LIVE it does not wo
View Count: 911
[2019-05-21 18:39:56] |
User327128 - Posts: 15 |
I made the correction you suggested and changed NO to YES and it makes NO difference the Auto does not work when I turn on LIVE it puts out dots on SIM but does not registrar any money on LIVE please make LIVE work also. Thank you I am trying to ask the question in the proper place please tell me if I am not to ask the questionwhere! thanks hh My auto system works good on SIM and does not registrar anything on LIVE can you help this situation it puts out dots green and yellow dots! |
[2019-05-22 17:22:43] |
Is this an ACSIL trading system or does it use the Spreadsheet System for Trading study? How was this trading system implemented?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-22 17:22:59
[2019-05-23 14:05:44] |
This is ACSIL type of automatic trading system
[2019-05-23 14:09:51] |
To answer your question this is a ACSIL type of trading system: Problem is it works on SIM but does not work or calculate on LIVE
[2019-05-23 23:01:52] |
Therefore, go through the procedure here: Automated Trading From an Advanced Custom Study: Debugging/Troubleshooting Automated Trading Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-24 00:38:10] |
I have come this far with my Automatic system from here on is over my Head! would be able to look at my "Alert Condition" and make any corrections to allow it to function I could copy it here for you to take a look at and make suggestions. Thanks hh
[2019-05-24 00:40:50] |
could I copy my "Alert Condition" here and have you make suggestions or corrections to allow it to work? hh
[2019-05-24 06:43:55] |
EdCarp - Posts: 25 |
Sierra may not be able to, but there are plenty of ACSIL coders here that could help.
[2019-05-24 08:25:52] |
could you put me in touch with a ACSIL Coder who could look at my "Alerts" and make the correction to get it working on LIVE I could respond by Email with the Alert if you like to keep it private.
[2019-05-24 08:27:15] |
Ackin - Posts: 1865 |
User327128) Hi, I have solved similar problems with a few people, often it is a bad synchronization of the calculation of individual alerts and next case too complicated procedure to calculate some value. If you want write me direct message. |
[2019-05-24 08:33:41] |
Or you could just post it here, and the entire community could help. :)
[2019-05-24 08:43:23] |
my email is: howardhess68@gmail.com
