Date/Time: Fri, 31 Jan 2025 16:02:18 +0000
Target Prices are not correct when submitting an order
View Count: 593
[2019-05-21 16:25:50] |
User312874 - Posts: 2 |
Hi - I am submitting a bracket order using the price option for target and stop. However, when I place the order it completely changes the pricing that I entered. I don't get this issue if I use ticks or %. I am trading the Bitmex pair ADAM19. I have attached screenshots. Thanks for your help. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=28551 https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=28552 https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=28553 |
[2019-05-21 23:17:54] |
The value you enter in the Limit Offset field is not an actual price, but is an offset from the parent price. Therefore, you are adding 0.00000950 to 0.00000922 for the Target, which gives you a final location of that Target order at 0.00001872. You will find the information on this here: Attached Orders: Offset Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
