Date/Time: Fri, 31 Jan 2025 17:43:21 +0000
Daily P/L value (in Trade Activity Log) changes to 0.00USD at midnight my local time
View Count: 690
[2019-05-21 16:09:59] |
User65931 - Posts: 18 |
I want to keep the profit or loss value in the Daily P/L column until 06:59.59(my local time) Current settings: All my Chart--> Chart Settings --> Advanced Setting --> Time Zone is set as: +9 jst, and also my Global Settings --> Data Trade/Service Settings --> Time Zone is set as: +9 jst . All my Chart --> Chart Settings --> Session Times --> Start time is set at 07:00:00, and End time is set at 06:59:59. Use Evening Sessing box is not checked. I think I am making a mistake in Trade Activity Log --> Date Range to Display. Ive tried "Todays date" or "Tomorrows Date" in the drop down menu, which doesnt seem to solve the problem. I am on version 1915. Ive read all the documentation. Can anyone help me? Thank you in advance. |
[2019-05-21 18:59:08] |
This is explained here: Trade Activity Log: Understanding Daily Trade Statistics Reset Time (Understanding Daily Trade Statistics Reset Time) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-21 18:59:59
[2019-05-22 16:58:54] |
I still cannot syncronize *Daily P/L* in *Trade Activity Log* with my Chart's Start to End period (about 23 hrs), and my timezone is +9hrs . This syncronicity should be a straightforward/automatic happening in Sierrachart. So I give up with Daily P/L and will just use Closed P/L. |
