Date/Time: Sat, 01 Mar 2025 01:05:44 +0000
Bar closing time
View Count: 1174
[2019-05-21 15:36:45] |
User116783 - Posts: 84 |
Hi, For a 1 minute bar, is the time that appears when you scroll over it the time that the bar opened or is it the time the bar closed? Thx ZS Edit: never-mind it's the opening price Date Time Of Last Edit: 2019-05-21 15:40:35
[2019-05-21 18:07:18] |
John - SC Support - Posts: 38292 |
Yes, that is correct. This information can be found here: Working With Charts: Time Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
