Date/Time: Fri, 29 Mar 2024 09:55:32 +0000
Manually drawn volume profile cannot be edited if Trade and Current Qoute Symbol is set
View Count: 543
[2019-05-20 19:49:52] |
User889191 - Posts: 61 |
Manually drawn volume profile cannot be edited if "Trade and Current Quote Symbol is set on chart". If "Use as Trade Only Symbol" is selected then it works. It works as well if "Trade and Current Qoute Symbol is set on chart" is empty. Please fix.
[2019-05-22 04:01:08] |
This will be resolved in the next release.
