Date/Time: Fri, 26 Apr 2024 03:04:25 +0000
Switching between Sim/Live Trading
View Count: 692
[2019-05-20 19:12:04] |
User606491 - Posts: 164 |
Switching between Sim and Live trading deletes the formulas I have in Row 2 of my spreadsheet. Specifically, this occurs on the concatenate formulas I've created in Row 2. These formulas are displayed on my charts. Why would this be the case? How do I prevent this?
[2019-05-21 17:54:01] |
Be sure that the data that you are generating in Row 2 for the formula columns is text only. If it is not text, then the data will be overwritten with the standard column headers. Refer to the information here for using formulas for the names in Row 2: Using the Spreadsheet Study: Using a Formula in Formula Columns Row 2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-21 18:31:37] |
Understood. Thank you.
