Date/Time: Thu, 28 Mar 2024 21:19:39 +0000
Price change per bar
View Count: 1153
[2019-05-20 13:12:46] |
grantx - Posts: 244 |
How do I get a text label under each bar indicating that bars price range? So, just like your 'Bar Numbering' study except it reflects the price range instead of the bar number. Thank you. Date Time Of Last Edit: 2019-05-20 13:53:24
[2019-05-20 18:47:12] |
John - SC Support - Posts: 30444 |
This Study Collection does what you are asking for, although it places the range above the bar. It can be changed to be below the bar, just look through how this is done to figure it out: https://www.sierrachart.com/AdditionalFiles/BarRangeTextAboveBar.StdyCollct Here is the information for how to use the Study Collection file: How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-20 19:29:45] |
Doesn't work for me as I only have package 3. However, it works perfectly using 'Bar difference' study and the 'above/below' study. Thank you Sierra support. Date Time Of Last Edit: 2019-05-20 19:30:37
[2019-05-22 00:59:00] |
There is no dependency on the service package with that study collection.
