Date/Time: Fri, 31 Jan 2025 16:39:28 +0000
SierraChart_64 does not have a valid digital signature
View Count: 1042
[2019-05-20 06:21:35] |
User553136 - Posts: 1 |
Hi - I downloaded Sierra Charts for the free trial but upon launching, Norton complains: "SierraChart_64 does not have a valid digital signature" (attached file screenshot). Is this correct? Thx |
Private File |
[2019-05-20 13:12:10] |
Sawtooth - Posts: 4164 |
Software Download: Antivirus/Anti-malware Software Flagging Sierra Chart Installer or other Files as Unsafe/Infected
[2019-05-20 16:13:06] |
Yes this is true but just skip over this security rule on your security software.
