Date/Time: Fri, 31 Jan 2025 16:39:23 +0000
Is it possible to create a custom menu with buttons?
View Count: 845
[2019-05-19 15:05:59] |
User932967 - Posts: 18 |
I'm a programmer but I'm new to SierraChart and I'm evaluating if it meets my needs. By programming it with its language it is possible to create a menu in the graph where to insert buttons like "Buy" and "Sell" and labels that show the desired content and input fields? Thank's Piero |
[2019-05-20 03:21:22] |
Yes. Refer to this page: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
