Date/Time: Sun, 24 Nov 2024 17:58:51 +0000
5 tick reversal in bonds
View Count: 1898
[2013-11-25 17:05:03] |
User17999 - Posts: 2 |
Please look at the picture seen in Time End Sale 400 contracts at 5:49:44 not see buying this bar, see 250 buyers and 50 sellers Is there an explanation? Thanks in advance |
Attachment Deleted. Attachment Deleted. Attachment Deleted. Attachment Deleted. bonds1.gif / V - Attached On 2013-11-25 16:58:56 UTC - Size: 256.82 KB - 475 views |
[2013-11-25 17:11:31] |
What is it you are trying to show us? This is not clear.
[2013-11-25 17:16:58] |
i put big pic
bonds2.jpg / V - Attached On 2013-11-25 17:16:32 UTC - Size: 254.68 KB - 479 views |
[2013-11-25 18:58:39] |
Do you have any Volume filter settings in Chart >> Chart Settings >> Advanced Settings 2, for the chart?
