Date/Time: Mon, 25 Nov 2024 05:33:19 +0000
.NET 4.0 Error
View Count: 2401
[2013-04-10 14:27:29] |
infpz - Posts: 826 |
Anyone see this before? http://screencast.com/t/OFN0JOqI This person is trying to update .NET because 962 will not load after InfinityAT launches. Log: S Version = 5.1.2600, Platform 2, Service Pack 3 OS Description = WinXP - x86 Professional Service Pack 3 CommandLine = C:\b0f0d7dc79d3b1d14e\\Setup.exe /x86 /x64 TimeZone = Eastern Daylight Time Initial LCID = 1033 Using Simultaneous Download and Install mechanism Operation: Installing Package Name = Microsoft .NET Framework 4 Setup Package Version = 4.0.30319 User Experience Data Collection Policy: UserControlled Number of applicable items: 6 ServiceControl operation succeeded! MSI (C:\b0f0d7dc79d3b1d14e\netfx_Extended_x86.msi) Installation failed. Msi Log: Microsoft .NET Framework 4 Setup_20130410_102235859-MSI_netfx_Extended_x86.msi.txt Final Result: Installation failed with error code: (0x80070643), "Fatal error during installation. " (Elapsed time: 0 00:00:40). |
[2013-04-10 16:18:49] |
In general, we sometimes have seen errors with .NET updates like this. They are not easily resolved. They would have to find out from the Microsoft Knowledge Base what the error code means and follow the given solution. We are working very aggressively now to get rid of this junk .NET from Sierra Chart. It is an absolute terrible thing. This is the relevant error line: Final Result: Installation failed with error code: (0x80070643), "Fatal error during installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-10 16:20:17
[2013-04-10 16:39:11] |
Just remembered we have a non-CLR/.NET version. They can install it using this link: http://www.sierrachart.com/downloads/SierraChartSetupNoCLR.exe The installation folder needs to be \SierraChart\SierraChartTransActMA They do not have to mess around with .NET at all. When updating this one always use Help >> Download Latest Non-.NET Version Although, there might actually be a small dependency on .NET in one of the TransAct libraries which would end up defeating this. We will check with Bob on this now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-10 16:40:17
[2013-04-10 17:16:03] |
OK, thanks, please let us know.
[2013-04-10 17:51:04] |
Our recommendation is to try using the Sierra Chart non-CLR version and see what happens. TransAct has indicated that there still is a dependency on .NET for one of the files. Although it still might work.
[2013-04-14 21:50:11] |
maxima120 - Posts: 144 |
We are working very aggressively now to get rid of this junk .NET from Sierra Chart. It is an absolute terrible thing. 4.5 years gone by but nothing changes under this sun :)
[2013-04-14 22:26:48] |
What exactly do you mean by this? If you are indicating that we are taking a long time to remove .NET, then it is just simply time-consuming. The problem is there are several components which we do not develop which use it, so we have to find alternatives for them or build them ourselves. At least we are doing this. We do not foresee .NET as the future. Developers should avoid it like the plague. And for years now, we have also made our non-CLR version available. At this point the only limitations are that the Spreadsheet functionality is still under development. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-18 00:36:43
[2014-01-17 23:16:33] |
bwalks123 - Posts: 122 |
Is .Net version 4.5 suitable or does it have to be .Net 4.0? Thanks |
[2014-01-18 00:35:12] |
4.5 is fine. And to give you an update, we really are only 2 months away from completely dropping .NET. So you will not even need .NET on the computer to begin with. You can also use the non-CLR version: http://www.sierrachart.com/index.php?l=doc/download.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-18 01:23:28] |
Oh ok great I am going to be paying for Sierra Chart package 3 and SC real time & historical feed with global futures/TTnet connection. I'm having issues downloading TT platform, keep receiving a message that says "ttm_api_4.2.dll" missing from computer? Any idea what this is? I'm still waiting to hear from TT support! Thx |
[2014-01-18 02:40:05] |
Not sure. That involves TT's own software. You should not have any trouble installing Sierra Chart. The installation is very straightforward. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
