Date/Time: Sun, 24 Nov 2024 20:48:09 +0000
TD Ameritrade Options Symbols Format
View Count: 1896
[2013-11-25 16:28:15]
jackw - Posts: 57
I am trying to add option symbols to a quoteboard using the TD Amertrade data feed.
I have tried using IBM DEC 21 2013 180 CALL, which is the options format used on their website. I have also tried IBM_122113C180, which is the format described in their API documentation.
Neither format returns data. Could you please let me know the proper format for options symbols for this data service.
[2013-11-26 23:52:31]
We are going to be looking into this as best as we can. Not sure though we will be able to offer a solution.
[2013-12-09 07:38:04]
This is an example of how you would specify the symbol within Sierra Chart:
VMF Jan 22 2011 25.0 Call
The letters apparently are case-sensitive. That could be the problem because you do not have the correct case in your given symbol.
Date Time Of Last Edit: 2013-12-09 07:39:40
