Date/Time: Fri, 31 Jan 2025 18:44:43 +0000
no many historic symbols for ES
View Count: 781
[2019-05-18 14:53:11] |
sierrasimon - Posts: 51 |
why does SC only show historic symbols until ESH19? I'm using SC Historical Data Service and have loaded 600 days back. I can't find anything about that in help or support board.
[2019-05-18 19:08:47] |
User138602 - Posts: 169 |
Did you select a "Continuous Contract" method? You find it under ChartSettings (2nd Tab)
Date Time Of Last Edit: 2019-05-18 19:09:14
[2019-05-18 21:31:00] |
Yes would be best that you just use the Continuous Futures Contract feature: Continuous Futures Contract Charts Also refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Using Expired Futures Contracts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-19 00:35:25] |
Yes, I am already using continuous Future Contracts, but when I display data from 2018 it loads always until the actual contract. So I tried to just type ESM18, but SC doesn't save this setting because it's not in the listings.
[2019-05-19 01:59:08] |
You can still use that symbol whether it is listed or not and you can also control the last date to load through the Chart >> Chart Settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-19 01:59:24
[2019-05-19 21:07:54] |
Yes, I know that I can use it, as I wrote, I already used it, but SC does not save this setting, so the next time it loads again all contracts until the actual. So the Question is: what can I do to find more historic symbols in the listing, f.e. ESM18?
[2019-05-20 14:08:11] |
Chart >> Chart Settings >> Use Date Range >> To is definitely a saved setting. Maybe the problem is what is described here: Unable to Change the Bar Time Period for Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-20 14:08:45
[2019-05-22 19:07:37] |
But I was talking about the following setting, that isn't saved: Chart >> Chart Settings >> Symbol I type the historic symbol, because it is not in the list. My question was: what can I do to find more historic symbols in the listing, f.e. ESM18? |
[2019-05-23 03:52:04] |
You just manually type/enter the symbol that you want. And the Symbol setting is saved. That is definite. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-23 03:52:11
[2019-05-26 19:57:17] |
"You just manually type/enter the symbol that you want." So what is in that case, when I want to load historical charts with more than one contract? The symbol setting temporarily is saved and then resets to the actual contract. Date Time Of Last Edit: 2019-05-26 19:58:14
[2019-05-26 23:10:20] |
Ok we now realize what the problem is because this was never making any sense to us. You must have this option enabled: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Uncheck it. Disable it. So what is in that case, when I want to load historical charts with more than one contract? You just also need to use the Continuous Futures Contract setting in this case as well.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-26 23:11:51
