Date/Time: Fri, 31 Jan 2025 16:59:09 +0000
ETH VPOC on RTH chart...
View Count: 1684
[2019-05-18 03:30:19] |
User629089 - Posts: 93 |
Hi, I've added a number of studies from ETH charts to an RTH chart through the "Study/Price Overlay" study. I'm trying to add the ETH/Overnight VPOC to an RTH chart and have set up everything the same way as the others and am having no luck. Under "Study to Overlay" I've got the correct chart and to the right of this I have "VbP for TPO chart." Under "Subgraphs" are the POC,VAH,etc. for this study. This however will not add the VPOC, etc. to the RTH chart. I'm wondering if there is another way entirely to do this or I'm just missing something. Can you help? Thanks... |
[2019-05-18 18:28:26] |
First, do not use a TPO chart as the source chart . Instead use a standard chart containing the Volume by Price study and you also have to enable these particular Subgraphs: Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-18 18:28:35
