Date/Time: Fri, 31 Jan 2025 15:54:59 +0000
Numbers bars
View Count: 604
[2019-05-17 19:37:50]
User799889 - Posts: 1
Can you please tell me if there is a possibility in numbers bars make the highlight for a given volume more or less than certain values?
[2019-05-17 21:15:22]
John - SC Support - Posts: 37624
If we are understanding what you are asking for, then set the Background Coloring Method to Based on Volume - Actual and then set the particular values you want to use for the separation of the colors in the Column # Actual Volume Compare Thresholds.
You will find the documentation for the Background Coloring methods here:
Numbers Bars: Numbers Bars Background Coloring Methods
You will find the documentation for the Column # Actual Volume Compare Thresholds here:
Numbers Bars: Column # Actual Volume Compare Thresholds
