Date/Time: Fri, 31 Jan 2025 15:54:51 +0000
Statistics?
View Count: 1009
[2019-05-16 22:04:47] |
User103219 - Posts: 8 |
Does sierra allow you to pull statistics? Like how often does the first 30 min hi hold for rth?
[2019-05-17 04:50:41] |
The closest that is available is this particular study: Relative Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-17 07:19:22] |
Acro - Posts: 441 |
Sierra provides all the data and studies that you can freely download. You then need to take that data and put it through eg excel or python to compile the statistics of interest. So, to answer your question not within Sierra but achievable in excel or python with Sierra data plus studies - Use Edit - Export Bar and Study Data to Text File - and then get to work on that data |
