Date/Time: Thu, 20 Mar 2025 18:28:37 +0000
replay Control Panel not Launching
View Count: 2477
[2019-05-16 20:30:53]
SITCOTrader - Posts: 9
Hi, I cant get the replay control panel to launch.
I checked earlier threads I onlly saw to check if it is off screen. It is not.
Have restarted the App and the computer. Let me know what else I might be able to try.
[2019-05-16 22:12:05]
User492288 - Posts: 28
Hi, click on menu Window, then reset windows
[2019-05-17 00:53:08]
As has been said you need to select Window >> Reset Windows and then open the replay control panel again through the Chart menu or Control Bar button.
[2019-05-26 21:36:29]
Refer to:
Replaying Charts: Chart Replay Window Not Visible
Date Time Of Last Edit: 2019-05-26 21:37:04
[2022-11-15 00:06:43]
User440951 - Posts: 54
I have the same problem but and I followed what is explained in this link :
I also restarted Sierra and the computer.
Nothing nor done the window still does not reappear. I'm lost and don't know what to do...
Someone to help me?
[2022-11-15 00:19:31]
Small precision if it can be of interest, I noticed that there is 1 hour of difference between my graphs (which are at the right time) and the time that there is displayed in the messages of the message "log window".
[2022-11-15 12:56:10]
Sierra_Chart Engineering - Posts: 18860
You should not have any trouble getting the replay window after following these instructions:
Do you still have a problem with this?
Regarding time zone differences, refer to this page for making adjustments to that:
Time Zone Setting
Date Time Of Last Edit: 2022-11-15 13:00:00
[2022-11-15 14:07:32]
Yes I followed all these instructions but I still can't display the replay window. I really don't know what else to do...
[2022-11-15 14:13:52]
We do see a problem with resetting the replay window. We are looking into it now.
[2022-11-15 14:17:44]
You need to select Chart >> Replay Chart >> Reset Replay Control Panel Window.
And we have updated the documentation.
Date Time Of Last Edit: 2022-11-15 14:20:14
[2022-11-15 19:01:39]
It's perfect the panel is back :) Thank you very much !
