Date/Time: Sun, 23 Feb 2025 18:42:30 +0000
Trading stocks
View Count: 1830
[2019-05-16 17:17:26] |
User818950 - Posts: 9 |
Hello, i want to start using Sierra Chart for day trading stocks on all US Exchanges. What broker would you recommend except Interactive Brokers, because of their restriction that they only accept trader with a minimum account from 25.000$? Thanks in advance, H. Weisser |
[2019-05-16 19:07:42] |
At this time we do not have any acceptable solution for trading US stocks other than Interactive Brokers. We will keep this in mind. Update: Meaning that we will look for other alternatives.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-17 00:52:13
[2021-02-21 14:53:15] |
Zodiac - Posts: 6 |
Has there been an update on this? I'm currently using your service for Futures and I love it. I would love to switch over to SC to trade stocks as well, however the cautious language regarding the IBKR API has me concerned.
[2021-02-22 09:12:51] |
No there is no update in regards to this at this time.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-22 09:12:57
