Date/Time: Wed, 08 May 2024 22:06:12 +0000
Trade Activity Log Total Profit/Loss
View Count: 594
[2019-05-16 15:39:06] |
User921987 - Posts: 234 |
I have 2 trades in my log and the commission per 3 contract trade (ie. line) is $2.22/RT. Using "Points - Ignore Quantity". I understand the correct value should be -1.87 + 2.63 = 0.76 How do you calculate the Total Profit/Loss of 0.38 ? Please see attached picture. The SierraChart version is 1915 64-bit (26980M) |
Private File |
[2019-05-17 05:53:31] |
Provide a screenshot showing that same window using "Points".
[2019-05-17 05:55:11] |
But basically the total that you see is calculated using "Points" and then divided by 6.
[2019-05-17 06:36:39] |
When using "Points" the total value is logical -5.61 + 7.89 = 2.28 But when ignoring the quantity the total value is not a sum of the printed lines in the log as I would except. I just see it a bit not logical :D Thank you for the clarification I understand the value now. Date Time Of Last Edit: 2019-05-17 06:43:57
Private File |
[2019-05-20 19:29:45] |
The documentation has been updated in regards to this.
