Date/Time: Fri, 31 Jan 2025 17:49:27 +0000
[Programming Help] - backtesting
View Count: 1980
[2019-05-16 11:17:44]
User512854 - Posts: 24
hi, i have few stocks i want to run backtesting on multiple time frames and few strategies too
1- is it possible to download , save the historical data in order to use for backtesting? and to download all in one go? because it is taking so much time
2- is it possible to autorun one strategy , at a time, for all the saved historical data of these stocks, then save the outcome in excel win rate and profit multiplier?
please advise on above, else the most common - best practise to save time
Many thanks,
[2019-05-17 22:31:35]
1. Yes. Are you referring to Intraday charts or Historical Daily charts?
2. Once you run a back test, the trading activity is automatically saved and can be viewed at any time. You can export it:
Trade Activity Log: Importing and Exporting Data
And you can change the trade account and run another back test and then keep the original results:
Auto Trade System Back Testing: Running Multiple Back Tests For Comparisons
Date Time Of Last Edit: 2019-05-17 22:32:17
[2019-05-18 11:55:17]
how to run backtest on multiple stocks in one go?
[2019-05-20 16:40:53]
Refer to:
Trade Menu: AutoTrade System Bar Based Backtest with Scan (Trade menu)
[2019-05-21 12:41:11]
right now , we have strategy done in dll but limited to 128conditions only, we want to increase that, is this possible? and how if so?
thank you
[2019-05-22 00:57:26]
What does the 128 refer to? This is not clear for us. When you say "condition", this is still just not clear for us.
[2019-05-22 12:21:23]
in coding, when programming new strategy, the file DLL is limited to 128 conditions only? please clarify if we can exceed
