Date/Time: Fri, 31 Jan 2025 16:44:38 +0000
not able to download newest version
View Count: 805
[2019-05-16 06:35:29] |
User13065 - Posts: 6 |
NOTICE: The version you are running is no longer supported. A request for the latest version has been started. The installer will begin when the download is complete. Time: 06:31:58 AM error message last 3 days. triied donloard button , error mesage not able to log on old version
[2019-05-16 10:38:57] |
Install Sierra Chart using this installer: Software Download: Software Download Exit from the current running of Sierra Chart first. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-17 03:05:05] |
got on last night same problem this morning, error message today same as yesterday
[2019-05-17 04:47:40] |
Did you update Sierra Chart using this installer?: Software Download: Software Download You will get version 1919 after the update. If not, refer to: Unable to Install the Newest Version of the Software Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-17 04:48:37
[2019-05-17 14:36:45] |
tried still not loading any other options
[2019-05-18 14:33:47] |
Install Sierra Chart into a different folder. Use this folder: C:\SierraChart2\ You should not have any problem with this. Once that is done, let us know and we will tell you how to copy the files over from the other installation folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
