Date/Time: Mon, 14 Sep 2026 16:20:30 +0000
Volume Bars Dominant side Auction Addition
View Count: 2045
| [2013-11-25 14:49:35] |
| TheCalmTrader - Posts: 32 |
Hello, I noticed that you included a Text on dominant side Auction with coloring percentages, Can you please include this option in the VbP study aswell? Also how about a difference of Bid x ask volume With auction side comparisons in Vbp ? Im sure it would be quick just change the arithmetic to diagonal instead of vertical. If you want you can tell me how to modify the vbp study and I can hire Somebody to do this and give you the code. Thanks Date Time Of Last Edit: 2013-11-25 14:51:55
| [2013-11-26 17:23:19] |
^ bumb just thought of an idea you could do a tri colored difference bar one green for X% above red for X% below and orange if there is x% presure from both sides at that price. But lemme know what you guys are thinking
| [2014-02-20 20:31:09] |
| Moti - Posts: 63 |
Please, Very important tool.
| [2014-02-20 23:59:01] |
I still dont know why they haven't adressed this problem or even commented |
