Date/Time: Thu, 28 Mar 2024 14:29:04 +0000
Rejected order
View Count: 698
[2019-05-15 18:20:57] |
Ronti - Posts: 6 |
Hi there, Related to yesterdays ticket. It seems yesterdays new connection isn't all that well after all. I wanted to test a small live trade right now but got this: " FXCM Live Trading (Standard) - DTC order update (Order reject). Info: FXCM order update (Rejected). Text: 19915;DAS 19915: ZDas Exception ORA-20102: Access Violation: CFD_U10R1_889FB548B4CB3574E0537C293C0AC770_05122019040003684915_ phase: 4.. Text: Tag: Standard_Target_Stop.twconfig. Internal Order ID: 1306. Service Order ID: 7405. Symbol: EURGBP | 2019-05-15 19:56:54 * " I should be on the right server. Limit order was well outside the spread. Attached: stop:stop target:limit quantity 1000 Is there something I do wrong or is there an issue here with attached orders? |
[2019-05-15 20:08:22] |
Can you please contact FXCM at: api@fxcm.com And let them know you are getting this particular error message: Text: 19915;DAS 19915: ZDas Exception ORA-20102: Access Violation: CFD_U10R1_889FB548B4CB3574E0537C293C0AC770_05122019040003684915_ phase: 4. This error message is from their system. Also give them your FXCM account number. They will be able to help you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-15 20:27:02
[2019-05-16 10:45:33] |
We did hear from FXCM about this. We are looking at their response and seeing what needs to be done. But we are still puzzled by the particular error. It does not make sense to us.
[2019-05-16 17:34:18] |
Ronti - Posts: 6 |
Ok thank you. I'll sit tight and wait for a solution. Date Time Of Last Edit: 2019-05-16 18:08:33
[2019-05-16 17:41:33] |
FXCM is working on resolving the problem. We will update you when complete.
[2019-05-20 19:26:49] |
We are contacting you by email now about this.
