Date/Time: Fri, 31 Jan 2025 14:36:56 +0000
Market Depth Historical Graph Request
View Count: 1139
[2019-05-15 15:06:17] |
tdd2672 - Posts: 61 |
Would it be possible to be able to show only the highest current value of the dom as well as anything that is within a set percentage? I see that we can set a particular value and a percentage of that value but to me that isn't beneficial over the course of the entire trading day. The average max value tends to fluctuate depending on the time of day, after hours, etc. I want to know the highest value at any given time regardless if its 50 or 500.
[2019-05-15 17:09:05] |
John - SC Support - Posts: 37621 |
If we understand correctly what you are asking for, this is already supported. Set the Input for Value Type for Graph Only Quantities Greater Or Equal To to Percentage of Maximum Depth, then set the percentage value you want to use in the Graph Only Quantities Greater or Equal To Input. Refer to the documentation on these fields starting here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#StudyInputs_ValueTypeForGraphOnlyQuantitiesGreaterOrEqualTo For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
