Date/Time: Fri, 31 Jan 2025 14:55:08 +0000
IB volume data on zig zag
View Count: 531
[2019-05-15 11:48:22] |
manfretto - Posts: 117 |
Hi, Is IB data feed for volume on zigzag chart accurate or only a sum of snapshots? Best Regards, slawomir |
[2019-05-15 15:46:42] |
It should be fairly accurate. While Interactive Brokers does provide snapshot type of data, Sierra Chart inserts trades based on the reported Daily volume to ensure the total volume for a chart bar is accurate.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-15 18:59:14
