Date/Time: Fri, 31 Jan 2025 14:48:00 +0000
[User Discussion] - regarding automation in sierra
View Count: 538
[2019-05-15 09:13:57] |
User479048 - Posts: 19 |
1. can we automate sierra from external application like dotnet. ? 2. is there any way to run tests in queue like multiple time frames? and then multiple scenarios? 3. how to save these scenarios meaning like using first time set of entry, exit, then in second time use another set of entry exit so on for multiple time frame like 30s, 1mn so on, so it run multiple times, mutilple timeframe, multiple logic then save the logs |
