Date/Time: Fri, 31 Jan 2025 13:51:37 +0000
Two Sierra Charts Accounts / Two Brokers
View Count: 674
[2019-05-15 03:16:05] |
Eric Uva - Posts: 6 |
I use two Sierra Chart accounts with two brokers (AMP / TopStep Trader). Each account requires different login and data feed credentials (obviously). How can I set up Sierra Chart so that I can automatically log into Sierra Chart and automatically "call" the appropriate data feed based on the broker I want to use? For example, when I want to use AMP, I would like to have the SC log-in and data feed credentials automatically pre-populated. |
[2019-05-15 05:26:10] |
There are two ways to accomplish this. One method is to install two copies of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Another method is described here: Data/Trade Service Settings: Saving and Loading Service Settings We really recommend using two separate copies of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
