Date/Time: Fri, 31 Jan 2025 13:38:06 +0000
Wrong session times for most symbols?
View Count: 724
[2019-05-15 02:40:38]
bfreis - Posts: 19
When I open the Symbol Settings, I can see that the session time settings for ES are correct. But if I open any other symbol, they are incorrect. And I'm talking about the "Default" settings, i.e., the ones that I cannot modify and that are automatically provided.
Why is this the case? Can it be fixed (other than me having to manually fix all that?)
I've attached a screenshot of the settings for ES where you can see that the Default values are correct, and another for NQ where you can see the Default values are incorrect (and this is the case for anything else).
imagees.png / V - Attached On 2019-05-15 02:40:15 UTC - Size: 43.99 KB - 281 views
imagenq.png / V - Attached On 2019-05-15 02:40:22 UTC - Size: 41.53 KB - 278 views
[2019-05-15 05:23:16]
We have added the session times for NQ for Interactive Brokers.
We are only willing to add Session Times for the most popular futures markets.
