Date/Time: Fri, 31 Jan 2025 13:49:16 +0000
ACSIL: sc.GetSymbolDataValue, SYMBOL_DATA_ASK_PRICE result is a double?
View Count: 640
[2019-05-14 20:32:40] |
TedMar - Posts: 190 |
if i pull ASK price with float SymbolAsk = sc.GetSymbolDataValue(SYMBOL_DATA_ASK_PRICE, p_Symbol, false, false);
, then result is a double, i get Warnings on compile. Most Instruments have a float Ask/bid Price. Please change return to float.
[2019-05-14 22:13:18] |
This will not change. You should learn how to do casting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-14 22:13:34
