Date/Time: Fri, 31 Jan 2025 14:58:11 +0000
Current price in the chart's axis
View Count: 786
[2019-05-14 18:55:40]
User21223 - Posts: 92
Hello
What needs to be set so that the current price is always in the chart's axis.
[2019-05-15 04:45:07]
We do not understand the basis of the question. This is always the case and cannot be changed.
Although in newer versions of Sierra Chart it is possible to not display the last trade price box altogether.
Date Time Of Last Edit: 2019-05-15 04:45:31
[2019-05-15 07:39:11]
I do not know if I explained it well. In the photo attachment.
imageaxis price.png / V - Attached On 2019-05-15 07:34:53 UTC - Size: 36.99 KB - 256 views
[2019-05-15 09:30:56]
I would like it to center the chart, after each price move.
[2019-05-15 17:14:07]
What you need to do is use a Constant Range Scale:
Chart Scale and Scale Adjusting: Using a Constant Range Scale
