Date/Time: Fri, 31 Jan 2025 15:57:24 +0000
Customize Chart Problem
View Count: 5543
[2019-05-14 16:14:02]
Forward - Posts: 65
Hello, when i try to open " Customize Chart/ Trade DOM Columns " happens nothing. If i click on the chart i hear a sound as a alert but no other.I searched any windows but nothing. The only thing to unlock SC is press Enter or ESC.
So what can i do to fix this problem ?
Thank you
[2019-05-15 05:49:47]
The prior answer given was incorrect, this issue is explained here:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.40 - Dialog Windows Do Not Display
[2019-05-17 18:32:19]
Forward - Posts: 65
mmmhhh i read the link but i don't think that the problem is that. I can open others windows, from Trade--> General Trade setting or Chart Dom Setting but not Customize Chart and Global Profit/Loss Management.
[2019-05-17 22:44:42]
Yes that is exactly the problem. Windows is not reliable in this regard. That is absolutely absolutely absolutely the problem. We know what we are talking about here.
