Date/Time: Fri, 31 Jan 2025 15:38:37 +0000
Vertical Scroll Option
View Count: 1367
[2019-05-14 12:36:06] |
Acro - Posts: 441 |
Hi, The vertical scroll feature does seem useful but one option seems missing. Could we have vertical scroll wheel to be defaulted to chart scrolling with shift being vertical scale scrolling. This would be more in line with how the scroll wheel has been used in previous versions but with the additional feature relating to the vertical scale. Thanks for considering |
[2019-05-14 18:29:54] |
Ok we will implement this.
[2019-05-16 08:12:34] |
Acro - Posts: 441 |
Thanks for adding the menu option for this. I'm assuming it's not functional yet as it does not scroll the vertical axis with shift in 1919 ?? |
[2019-05-16 16:11:59] |
No, this is not yet implemented. We did not yet get a chance to do that.
