Date/Time: Tue, 15 Sep 2026 20:02:24 +0000
Triggered Limit Order Type
View Count: 1356
[2019-05-14 10:34:12]
User255315 - Posts: 133
Could you please share the relevant documentation of which ORDER FIELDS are to be set when using the Triggered Limit Order Type in ACSIL?
Also correct me if I'm wrong, as i understand the concept, its a client-side (i.e managed by Sierra) order type that sends a limit order at a specific offset from the TRIGGER PRICE, which is the price at which execution of the order will take place (but may not accumulate a position depending on the offset).
[2019-05-15 05:46:58]
When used as the main order, the Limit is set with s_SCNewOrder::Price1 and the Trigger is set with s_SCNewOrder::Price2.
Here is the documentation for the order type:
Order Types: Triggered Limit
