Date/Time: Fri, 31 Jan 2025 13:43:29 +0000
increasing connection limit
View Count: 1023
[2019-05-14 04:36:41] |
User735389 - Posts: 189 |
I have sierrachart running on 3 different computers, which was working before but today it was showing an error about having too many connections. Can you guys increase this limit for me to 3? I build a lot of custom stuff and now have a 'server' on aws (which bridges to mt4), an indicator server to offload and manage indicators, and a primary trading client. thanks
[2019-05-14 05:15:32] |
What is the exact error message you are seeing? We need to understand where it is coming from.
[2019-05-14 05:28:35] |
This occurs right when i try to log in on a 3rd computer. "This login has exceeded the number of allowed systems. If you have restarted Sierra Chart or have closed Sierra Chart on one system and using it on another, you may need to wait 3 minutes... To increase the number of allowed systems contact Sierra Chart support."
[2019-05-14 05:49:38] |
You can activate additional systems here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
