Date/Time: Fri, 31 Jan 2025 13:55:24 +0000
How to move the attached DOM from left side of the chart to right side of the chart?
View Count: 907
[2019-05-14 03:19:48] |
User792505 - Posts: 1 |
How to move the attached DOM from left side of the chart to right side of the chart? I can move the floating DOM easily, anywhere, not the attached DOM. Am I missing something or its not movable? I get used to see the DOM on the right side. :) |
[2019-05-14 05:14:41] |
Log into this Support Board with Help >> Support Board from within Sierra Chart and let us know when that is done.
