Date/Time: Fri, 31 Jan 2025 15:46:39 +0000
Historical Chart
View Count: 596
[2019-05-13 19:21:11] |
user5324 - Posts: 10 |
I am trying to look at the historical chart for soybeans (ZS), but can only look at different contracts. What tickers do I enter to view the long-term historical chart?
[2019-05-14 19:37:36] |
You need to uses the Continuous Futures Contract feature. Refer to the information here: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-21 13:26:10] |
Thank you for the help, but the chart is still not showing the last several years of history...? I have tried every option under Continuous Chart under Advanced Settings.
[2019-05-21 15:31:20] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
