Date/Time: Fri, 31 Jan 2025 14:41:59 +0000
Downloading Multiple Historical Symbol Data - Multiple Symbols At Once
View Count: 1309
[2019-05-13 17:53:04]
User9415867 - Posts: 41
I scan 200 stock symbols each day and when I click on the symbol I have to wait for prior historical data to download. Is there a way to download all of the symbols at once so I can quickly scroll through the symbols once the download is complete?
[2019-05-14 05:10:38]
Is this for a Historical Daily or Intraday chart?
[2019-05-14 10:45:12]
Daily
[2019-05-14 19:41:51]
Therefore, use this command:
Edit Menu: Edit >> Download Data for Associated Watch List Symbols
[2019-05-15 01:58:38]
When I try to select 'download data for all symbols in watchlist' it is grayed out. It won't allow me to select it. I opened a watchlist from a chart that has daily bars and then tried to do it from that chart from the 'edit' drop down. It wouldnt allow me to.
[2019-05-15 02:46:51]
As long as the active chart is a Historical Daily chart and that chart has a list of symbols set in its Symbol List, then that command will be active and data will be downloaded for them.
[2019-05-15 10:52:18]
See attached for what is showing up.
image2019-05-15_065032.png / V - Attached On 2019-05-15 10:51:51 UTC - Size: 84.82 KB - 283 views
[2019-05-16 03:20:21]
That is not a Historical Daily chart but Daily bars built from Intraday data.
In this particular case add the symbols to the Intraday File Update List:
Global Settings Menu: Intraday File Update List (Global Settings menu)
To have the Intraday data downloaded for them when connected to the data feed.
Date Time Of Last Edit: 2019-05-16 03:20:47
