Date/Time: Fri, 31 Jan 2025 13:46:42 +0000
x&y constant relationship
View Count: 892
[2019-05-13 16:14:30] |
User834202 - Posts: 3 |
Hello I try to set the scale x&y constant relationship but the option is inactive in my program. How can I set it? |
[2019-05-14 05:48:33] |
Follow the instructions here: Chart Scale and Scale Adjusting: X & Y Constant Relationship Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
