Date/Time: Sun, 24 Nov 2024 18:48:10 +0000
[User Discussion] - Alert before bar ends
View Count: 1842
[2013-11-25 07:52:20]
Ronin - Posts: 35
I'm looking to set an alert on a count down timer before a new bar is formed
what condition should I type for lets say 60 sec before a new bar?
thank you
[2013-11-25 13:45:59]
Sawtooth - Posts: 4119
Have a look at this thread from the old forum:
http://www.sierrachart.com/supportboard/showthread.php?t=32613
[2013-11-27 12:32:11]
Ronin - Posts: 35
thank you, will look into it
[2013-11-28 15:20:23]
Ronin - Posts: 35
Hi tomgilb,
I don't understand how to use it, few questions please:
At first I added this study to a 60 min chart and could see the synced parameters on sheet 35, then I added it to a 1 min chart in order to test it but the sheet hasn't changed to 1 min chart (no new spreadsheet was created as well) -
1. where should I be able to see the 1 min sheet and edit it?
2. what is the difference between sheet 1 and 35?
3. where should I enter the values required - on sheet 35 or 1? (K1,L1 ...)
4. how can I set an alert to be active from certain selected hours - for example - from 08:30 to 17:00 on a 60 min chart
thank you for the kind help
[2013-11-28 18:05:26]
Here's an updated version that allows an alert period:
http://www.sawtoothtrade.com/free-stuff-11.html
Follow the instructions on that page if you apply it to a chart number other than Chart #1.
Let me know if you need further help.
Date Time Of Last Edit: 2015-08-14 01:47:08
