Date/Time: Fri, 31 Jan 2025 19:54:38 +0000
Trade Activity Log dropdown
View Count: 762
[2019-05-13 04:24:59] |
User376341 - Posts: 37 |
What is the attached dropdown called in the Trade Activity Log It doesn't seem to be documented |
Capture3.PNG / V - Attached On 2019-05-13 04:24:14 UTC - Size: 13.48 KB - 271 views |
[2019-05-13 16:23:45] |
Here is the documentation for this: Trade Activity Log: Note Filter Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-28 01:12:06] |
Unrelated to subject.... Is there a way, besides contacting broker, to find out the ip of the trading endpoint e.g for gain, The Data/trades service settings window shows prod.gainfutures.com yet that cant be "ping"ed Just trying to optimize transit times |
[2019-05-28 09:43:33] |
Usually you cannot ping a trading server.
[2019-05-28 11:51:57] |
unrelated Cant figure out what the "DPL" is on the attached snapshot, is it part of the Chart Trade Mode Box - Simulation configuration? I dont know how to remove the DPL, if you know how pls |
Capture.PNG / V - Attached On 2019-05-28 11:51:15 UTC - Size: 4.29 KB - 240 views |
[2019-05-29 16:35:40] |
John - SC Support - Posts: 37651 |
DPL is the Daily Profit/Loss. Refer to this section of the documentation for information on that display and how to remove it: Chart Trading and the Chart DOM: Daily Profit/Loss For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
