Date/Time: Fri, 31 Jan 2025 13:50:06 +0000
Draw horizontal line based on number bar volume
View Count: 2257
[2019-05-12 23:34:37]
User876097 - Posts: 14
Is there a way to have a horizontal line (ray) drawn based on a certain volume threshold of a number bar?
and is there an index of all the user contributed studies somewhere? I cannot seem to find one similar to the normal SC studies page.
[2019-05-13 04:12:53]
1. This study can do this:
Volume at Price Threshold Alert V2
We cannot provide any help for user contributed studies. There is no documentation for them.
[2019-05-13 07:30:28]
Thank you,
This indicator will mark either volume for bid, ask, or bid+ask volume. I need the exact same thing except for a total bar volume. for example >2000 volume
[2019-05-13 08:16:34]
I found an indicator that works for this: Color bar based on alert condition.
The problem is the line extensions are not showing if set to YES, extended until end of chart. I have the study set to the bottom of the list on studies to graph like explained.
Date Time Of Last Edit: 2019-05-13 15:07:44
[2019-05-13 21:28:30]
John - SC Support - Posts: 37621
You need to set the Input Setting Output When Condition True to Use Input Data. Then make sure the Input Data is set to where you want the extension lines drawn.
You will find the documentation on this here:
Color Bar Based on Alert Condition: Output When Condition Is True
