Date/Time: Fri, 31 Jan 2025 13:57:49 +0000
Spreadsheet Buy Entry Failure to Launch
View Count: 741
[2019-05-12 19:32:35]
User312841 - Posts: 26
I want to use the Spreadsheet to launch buy orders, and use Attached Orders to set a bracket trade. Had to hardcode the quantity in j26 because it kept defaulting to 1 after each initial hit. As you can see in K3 the formula is true, but the Attached Order did not trigger. How do I troubleshoot this???
Note: this was working for awhile, then I tested another stop method and has not worked since.
http://www.sierrachart.com/image.php?Image=1557688674838.png
[2019-05-13 04:56:54]
OK I found the problem. Max Long Position was set to 1000, so when I increased the position to 2500 it stopped working.
[2019-05-13 16:54:20]
Ok that is good.
What we were going to say is make sure the Attached Orders have a Time in Force of Good till Canceled:
Attached Orders: Time In Force
Maybe they were getting canceled earlier.
Date Time Of Last Edit: 2019-05-13 16:55:01
