Date/Time: Fri, 31 Jan 2025 13:48:46 +0000
1917 & Control Bars
View Count: 728
[2019-05-12 03:06:42] |
Acro - Posts: 441 |
1917 has altered the size of one of my control bars on one of my charts. The CB buttons are now two to three times wider than before so I miss half of my buttons. On that chart it does not matter which CB I place - they are all huge. This problem does not manifest itself on any other chart or if I create a new chart. I can rebuild that chart from scratch but it's painful. Here's an image of the widened buttons |
SierraChart_64_2019-05-12_10-59-17.png / V - Attached On 2019-05-12 03:06:32 UTC - Size: 1.94 KB - 321 views |
[2019-05-12 03:09:38] |
Do you know why the buttons are all blank?
[2019-05-12 03:16:43] |
Acro - Posts: 441 |
I have the beginning buttons blank on that control bar so I have my Trading buttons towards the right of the screen. It is the left monitor of a dual monitor setup Edit - I have rebuilt that chart now as I wanted to take advantage of vertical scroll wheel Date Time Of Last Edit: 2019-05-12 03:17:10
[2019-05-14 06:41:43] |
Acro - Posts: 441 |
Update - this issue still persists in 1918 ie randomly the control bars on some charts have buttons that are double width. I hope it does get resolved |
[2019-05-14 19:31:14] |
We are still not able to reproduce this. In the Customize Control Bar window, make sure this option is unchecked: Use Same Size for Control Bar Buttons . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-14 19:31:34
