Date/Time: Sun, 24 Nov 2024 17:52:46 +0000
Text on Dominant Side of Auction in Numbers Bars.
View Count: 1743
[2013-11-25 03:29:41] |
Rino - Posts: 124 |
I would like to set the value to higher then 100% to show extremes, like 300% and so. Thanks |
[2013-11-25 04:06:19] |
We will look into this.
[2013-11-25 04:11:13] |
Al SC Developer - Posts: 434 |
This can be done now, just set the compare values for the column using "Text on Dominant Side Auction" column to 300 for 300%. This is new functionality with the recent changes, so the doc still needs to be updated (will be done shortly).
Date Time Of Last Edit: 2013-11-25 04:12:02
[2013-11-26 15:30:06] |
Rino - Posts: 124 |
I now have it set to white for UP 76-100% and Down 76-100% and the rest black. (Just posting so others can see it). Helps using with Ask/Bid Volume Difference Bars. http://www.sierrachart.com/image.php?l=1385479400130.png Thanks Al. How do I do what you posted? http://tinypic.com/r/219e00p/5 (Sorry, not sure how to post a snapshot otherwise) |
[2013-11-27 01:12:23] |
emp0804 - Posts: 31 |
Rino- Would you be so kind to send me your chart definition. I must be missing a setting somewhere. My email is scott@bigsynth.com Thanks! Scott |
