Date/Time: Fri, 31 Jan 2025 13:44:48 +0000
Get/Set study input other than Int, Float?
View Count: 753
[2019-05-11 10:52:53] |
User353585 - Posts: 66 |
Hello, I've been using ACSIL for adjusting study settings, etc. which has proven to be very useful. I'd like to get/set Number bar study inputs, to be specific "Column 1 Actual Volume Thresholds (In:112)" using ACSIL. It has input form like "10, 20, 30". I tried sc.GetChartStudyInputInt, sc.GetChartStudyInputFloat with no success. Is there any way to access(get and set) the study input? Date Time Of Last Edit: 2019-05-11 10:56:04
[2019-05-12 02:02:29] |
These new ACSIL functions will be out in the next release to support strings: int (SCDLLCALL* GetChartStudyInputString)(int ChartNumber, int StudyID, int InputIndex, SCString& r_StringValue); int (SCDLLCALL* SetChartStudyInputString)(int ChartNumber, int StudyID, int InputIndex, const SCString& StringValue); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-12 02:02:55
