Date/Time: Tue, 29 Sep 2026 11:55:19 +0000
Custom Calculated Symbols
View Count: 1376
[2019-05-11 08:20:07]
Async - Posts: 24
Is this feature removed from new version? Or it's only removed for SC Futures Order Routing Service?
[2019-05-12 03:48:06]
No, it has not been removed.
Perhaps if you are having a problem with it, it might relate to the new symbol settings changes. Check the relevant settings in Global Settings >> Symbol Settings. This is going to be most likely the reason for the problem.
Date Time Of Last Edit: 2019-05-12 03:48:24
[2019-05-12 18:33:30]
bfreis - Posts: 19
I can't find the "New" button to create a custom symbol in the symbol list at Global Settings >> Symbol Settings.
If the feature has not been removed, what exactly should I do to add a custom calculated symbol now? The instructions at Custom Calculated Symbols: Instructions don't seem to work anymore.
imageScreenshot 2019-05-12 11.29.19.png / V - Attached On 2019-05-12 18:31:09 UTC - Size: 61.5 KB - 513 views
[2019-05-12 22:24:00]
Ok this is a good point. We need to work on that. We will make this a priority. We will get support out this week for this.
Date Time Of Last Edit: 2019-05-12 22:24:19
[2019-06-19 19:24:39]
jmt816 - Posts: 45
Any update on this issue? The instructions and screenshots do not match the current Symbol Settings dialog. I am attempting to create a custom derived symbol, and according to the current instructions:
"Enable the Uses Formula Operators option. This is absolutely essential to have this option enabled."
There is no "advanced" tab, nor could I find I any item within the inputs in the dialog to handle this.
Thanks,
Jeff
[2019-06-19 19:47:44]
You need to update to the latest version of Sierra Chart to add a new symbol to the Symbol Settings. Refer to:
The documentation still has to be updated but it should be clear what to do. If you need further help please wait for the documentation updates. Just allow about a week.
Date Time Of Last Edit: 2019-06-19 22:21:18
